Nous sommes le Ven 30 Oct 2026, 04:46
MessagePosté: Jeu 29 Oct 2026, 20:47
For a dance practice session, I am adding recorded counts to a generated backing track. A buzzing texture appears during the opening bars, close to the first movement cue. The recording is intended for learning a sequence, with clear timing as the main requirement. I encountered remove suno artifacts while researching the buzz, and I want to evaluate any processing against that practical requirement. A reduction in buzzing might help, but I still need to establish whether the timing cues survive any processing. Should the comparison include the spoken introduction and an entire phrase at normal practice volume? I can keep the spoken layer identical so the backing track is the only part that changes. The check would include the downbeat and sharp rhythmic cues, rather than focusing only on the buzzing. Which timing change would make you reject a processed version even if its background sounded cleaner?
https://removeaudioartifacts.top
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 66 invités
